Providing your 2000e does not have the optional ABS, in which case it would have rear discs, then the rear arm from any 2wd Sierra from 1987 onwards with drum brakes will fit (excluding estates obviously). Chances are though that you will need a replacement rear shock absorber as well as these twist easily @ the base where they go into the lower arm in this sort of impact.
Your best bet, therefore, would be to go to a local car breakers.
I did not note where you are located? If in the SE, I can recommend a couple of good locations which will have plentiful stock for you.
iansoutham
Member Since 04 Jan 2009Offline Last Active Aug 13 2009 08:37 PM
Find content
Not Telling
