Support the club!
RDelaCourt
Member Since 09 May 2012
Offline Last Active May 23 2013 01:31 AM
Issues Timing My Engine
18 May 2013 - 11:17 AM
hi guys i hope someone can  help  me. i had to change  the camshaft chain tensioner on my 2005 ford fiesta TDCI (mk6). After fitting the new camshaft chain tensioner I timed the engine correctly using the correct timing pins.(i also rotated the engine  by hand clockwise through 12 cycles  with no issues, everything  was sound) Unfortunately after piecing everything back together i realised that i had forgot to put the cam shaft oil seal on!!!! so i began taking everything  off again. fitted the new oil seal and again put everything back  together. this time however i could only get about half a turn from the crankshaft i took the belt off and the crankshaft with nothing attached to it and it still wouldn't rotate. I don't know if the valves are hitting or getting jammed on something I've read up online that the fuel pump sprocket needs to be taken out then the engine should be timed and then put back in (apparently the fuel pump runs on a chain which is connected to the camshaft.)
Any help on this would be greatly appreciated.
Thanks in advance guys!
Timing A Fiesta Engine
25 February 2013 - 12:52 PM
Hi guys, I have a 2005 Ford fiesta TDCI zetec S, I had to replace the timing chain so ive had to take the rocker cover and cams out of the engine. Ive now assigned the cams position correctly, but no i have to time the rest of the engine. does anyone have any PDF's or photots they could please help me with?
Thank in advance
Ryan
Fiesta Tdci Mk6 Oil Switch Thread Size?
12 February 2013 - 01:22 PM
Hi guys, i have a 2005 ford fiesta tdci (mk6) and was wondering if anyone knows what the size of the thread of the oil switch is? Ive rung Ford and they dont know!
Thank you!
Oil Pressure Gauge Help!
02 February 2013 - 11:10 AM
Hi there guys i' hoping someone can help me i have a 2005 ford fiesta zetec s tdci and ive just put a new engine in due to the previous engine failing. ive just finished fitting the new engine in but the oil light is coming up but when hold the revs up slightly the light goes off. so i bought an oil pressure gauge along with a boost gauge and a oil temperature gauge. but the t-piece ive bought separately doesn't fit into the engine block (its a t-piece)
so has anyone here fitting gauges to their fiesta? please could someone back to me regarding this.
Thanks in advance
Ryan
