Support the club!
dance008
Member Since 15 May 2012
Offline Last Active May 20 2012 10:23 PM
In Topic: Ford Fiesta Zetec S Puma Conversion Not Running Right
18 May 2012 - 05:45 PM
cheers everyone for the help, but seeing as  i have changed nearly everything, i found that the only problem could now be the map sensor on the air box, i took it off, and the pins on the sensor that go into the box, one of them had black gunk on it, so a bit of brake cleaner and a careful cotton wool bud sorted it. jumped in, and ragged the hell out of it.
stress over, thanks for the comments though guys.
17 May 2012 - 05:20 PM
yes sound like the clutch plate.
17 May 2012 - 05:17 PM
ok i got it wrong, it IS a 1.7 conversion, and no its not the clutch as its not over revving it wont go past say 4000 rpm, then take your foor off the accelerator a bit and it will go round,, i put a new lambda sensor on it again today for a 1.7 and still no luck, but is running a bit better, think its still the lambda?
the maf sensor has been crimped on i will add, but would this matter.
