in FF2 platform (so also Kuga) scandinavian lights are purely hardware - no software
- → Viewing Profile: Posts: mayak
Support the club!
- Group Members
- Active Posts 26
- Profile Views 221
- Member Title Member
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Male
Ford Model
Focus mk 2
Ford Year
2007
UK/Ireland Location
Other/NonUK
Annual Mileage
0 to 5000
Contact Information
- First Name Marcin
User Tools
Latest Visitors
In Topic: Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
29 April 2013 - 02:24 PM
28 April 2013 - 08:07 PM
James,
quite nice description how to add a switch to ELM327 - but 4 prongs switch (without neutral position) will work fine.
My biggest remark is that putty is completely not needed to enable MS-CAN
in ELMConfig, because Sergey had taken care of that: in old versions
there was a button to enable MS-CAN n right upper corner, and in later
versions ou need to press 'ELM327 setup' from first screen and then
press 'Setup ELM327 for MS-CAN bus' (prior to hitting this button, you
need to select the right speed and port number) - ELMConfig will send
those commands that you type in putty. Much easier.
19 April 2013 - 01:06 PM
Busy using it already.....arrived yesterday. So far so good !
Literally, what more can configure this program in Focus2 comparing to ELMConfig? I know it can adjust millage and flash PCM so it means that UCDS can enable cruise control in FF2. Anything more?
In S-Max - are there more options in car central configuration in BCM in comparision to ELMConfig? Are there any configuration options in IPC (instrument cluster)? Have you tried to enable displaying instant fuel consumption in your (old) analogue cluster?
Thanks Richard! ![]()
20 March 2013 - 09:49 PM
I'm not sure, but there was something about it in Russian thread about ELMConfig: they said (maybe Civil-zz, maybe someone else) that in rom level 509 instant consuption is less frequently refreshed on a display
14 March 2013 - 09:09 PM
Do I need to do the setup for MS-CAN?
yes, you do
- Privacy Policy
Find content
