Member Since 17 May 2012
Offline Last Active Aug 26 2014 07:48 AM
#356187 Mk7 Door Seal
Posted by david295 on 23 April 2014 - 10:26 AM
Ford told me about the fix they did on mine and showed me how.
The seal is actually stuck on to the black plastic trim that folds around the door, where infact it should be stuck to the door it self.
they took my old seal off, cut the plastic that wraps around door under the seal, and stuck the new seal direct on to door.
If you dont understand let me know and i will go take some pictures.
#343998 Stripes
Posted by david295 on 17 March 2014 - 07:05 PM
To be honest I don't care that I could of got them cheaper, I got what I wanted at a price I was happy at.
I will also be buying my body kit direct from Ford, yes it may be expensive, but not to worry it's my money.
#343966 Stripes
Posted by david295 on 17 March 2014 - 06:11 PM
I prefer to buy genuine ones not copies.
#301731 Identify This Hose And Use.
Posted by david295 on 02 November 2013 - 02:39 PM
It should be connected to air filter box, you will find a hole for it, look all around your filter box.
#298295 Headlight Bulbs Recommendations Please
Posted by david295 on 21 October 2013 - 08:57 AM
Thanks for all comments
Am going to go for  OSRAM NIGHT BREAKER UNLIMITED, I normally get my parts from Euro Car Parts, but they have none in stock, so will order them, as I do not want to go to Halfrauds.
#297705 Windows Steaming Up
Posted by david295 on 18 October 2013 - 11:01 AM
You need too reset the windows.....use only the first click on the switch and hold up and once it reaches the top, keep holding you should hear a little click within a second...thats the window reset for the fully closed position...do the same for going downwards and use only the first click of the switch
How would this cause the windows to steam up.
#276254 Making Air Con Colder
Posted by david295 on 20 July 2013 - 08:14 AM
I will take some pics
#248347 Advice Please
Posted by david295 on 01 April 2013 - 11:00 AM
maybe renew the gearbox oil while your in about it......
I did this less than 1000 miles ago
#248346 Advice Please
Posted by david295 on 01 April 2013 - 10:58 AM
The first pic is the slave cylinder i got with clutch kit, the 2nd pic is what all the vids i have whatched have said i need, which is the correct one for a 2litre mk1 2000
#248104 Advice Please
Posted by david295 on 31 March 2013 - 11:30 AM
Mark 1 2000  2litre.  its got 154 thousand on clock
I am having my engine taken out on Tuesday to change clutch, (I find it easier to do it that way, also enging is getting blasted to clean it) I am also changing water pump and cam belt + tensioners etc etc.
I am just looking for advice on what other parts I can change whilst it is out, oil seals gaskets etc etc.
