V1M4L
Member Since 24 May 2012
Offline Last Active Apr 15 2013 06:26 AM
In Topic: M7 Cigar Lighter Fuse
14 April 2013 - 07:34 AM
Just been to Halfords to get some 20amp mini fuses as my power outlet is dead. Its started raining now so can't fit them at the moment. Just wondering though, is it the engine compartment fuse box or the glove box one? (And if it is the glove box one how do I get access to it.
Fuse position 22 I think the hand book says.
Take everything out of the glove box 1st and then push in from the outside where you can see a little lip on each side...the glove box will drop so you can see the fuse box.
In Topic: Fitting Zetec S Rear Spoiler
08 March 2013 - 05:36 PM
Its easy to change...washer tube doesn't reach...I was surprised how easy it was. Best thing to do is to push the brake wire through the hole and then connect to brake light ans screw in place.
In Topic: Fiesta Heaters Always Blowing Hot!
24 January 2013 - 08:02 AM
Is it easy to change? I've got same problem :( any idea how much it is?
In Topic: Pumping Sound Possibly Rear Of Car
01 January 2013 - 11:06 PM
Its not a hissing sound..it sounds weird...hard to explain tbh. probably take to kwik fit and get it checked
In Topic: The Final Photos...
09 December 2012 - 10:20 PM
What you getting next?
