StevoBow
Member Since 29 May 2012
Offline Last Active Aug 11 2012 10:27 AM
Annoying Buzzing Noise From Beneath The Stereo...
29 May 2012 - 03:51 PM
Hi Guys... just a quick little 'How to' for that annoying noise you get with the titanium fiesta...
Firstly you have to remove the plastic around the gear lever... Just have to pull it up to do so.
Attached File  IMG_3346.PNG   990.64KB   219 downloads
Next... Remove the little bit of plastic under the radio... small flat blade screwdriver in the center and it should pop open and all you have to do is gently pull it off.
Attached File  IMG_3347.PNG   921.06KB   202 downloads
Next... Remove the trim around the climate unit which is held in by a few metal clips.. Gently pull it and it should all pull away. I started at the bottom and worked my way slowly to the top.
Attached File  IMG_3345.PNG   882.13KB   232 downloads
Next... Unscrew the 4 torx holding in the Climate unit and the 2 holding the clip above and disconnect the unit. Very easy,, 2 clips that you press the top down and slide the black part across (not in the pic but makes sense when its in front of you)
Attached File  IMG_3348.PNG   914.83KB   350 downloads
In the hole you'll find this... the cause of the problem!! It's vibrating against the trim. The trim is somehow acting like a speaker and making the noise far worse then it is!!
Attached File  IMG_3349.PNG   963.47KB   384 downloads
Cable tie it to the wires for the climate control and it should fix the problem!!
Attached File  IMG_3350.PNG   917.63KB   317 downloads
Now all you gotta do is put it all back together in reverse!!
Good Luck :D
