Member Since 10 Jan 2009
Offline Last Active Jan 11 2009 03:48 PM
Rear to adjustment buch stuck
10 January 2009 - 11:59 AM
I`ve just tried to have my wheels all alligned but the guy in the garage said he couldn`t do one of the rears as the bush used to make the adjustment has siezed. he said I need to replace the whole arm as the bush isn`t supplied on its own.
I`ve had a look myself and the cam bolt dosn`t rotate as it should instead when you try to turn it the whole bush tries to rotate, which it can`t cos it fixed to the arm.
The new arm is 30 but in order to fit it I`ll have to remove the cam bolt which I can`t cos it`s siezed! I`ve seen elsewhere that people have had to angle grind the bolt off :( don`t fancy trying that although I do have a small grinder.
I`ve tried penetrating oil to free up the bolt but no luck so far.
Any ideas how to free the bolt to allow adjustment?
How to easily remove the bolt / arm to allow a replacement?
PS its a 04 Reg Mondeo 2.0 TDi if that helps.
Steering / Braking judder
10 January 2009 - 11:48 AM
I have a 2004 reg Mondeo 2.0 TDi which has developed a judder which I can feel both when cruising along the motorway (50+ mph) and also when braking (any speed). At first I changed the front brake pads which reduced the severity of the issue considerably but didn`t completely solve it. Next the rear pads got changed, slight judder still there. Finally I`ve had the wheels rebalanced but still the judder is there.
Some other info:
I didn`t change the pads cos thay all looked nearly new.
All the wheels and tyres are brand new. I bought new alloys after the orginal ones corroded leading to rim leaks and constant slow punctures :(
The car has another issue of pulling to the left but I know that is down to a misalligned rear toe adjustment arm (see my other post).
I did ask Quik Fit to rebalance all the wheels but I`m fairly sure they only did the fronts.
I`m quite happy to tackle any task on the car, have built kit car in the past and have a garage full of tools :) So avoiding high garage costs would be nice but if it needs specialist tools then I`ll have to fork out :(
Some Questions:
If its not the pads or the wheels, what else could it be?
How do I check "washout" on the new pads and how do you adjust it?
Any other thoughts / ideas?
Any help much appreciated.
