garmcqui
Member Since 05 Jun 2012
Offline Last Active Jul 08 2012 01:12 PM
2008 1.8Tdci - Engine Management Light - Dtc Codes
07 July 2012 - 07:29 PM
Hi all,
A few weeks ago the engine management light came on on my mum's 2008 Focus 1.8 TDCi, accompanied by a whooshing noise under acceleration. I found a split in the pipe coming from the turbo, and replaced that with a genuine part.
It drove well for a few weeks, but now has had the engine manegement and traction control lights come on again. Not sure if the 2 lights are related...
I hooked up my F-Super USB and got the following codes from the PCM:
  • P0402 - EGR flow excessive detected
  • P0238 - Turbo/Super charger boost sensor A circuit high
  • P010F - Mass or volume air flow sensor A/B correlation
All three faults come back immediatedly after clearing.
From the ABS module, I got:
  • U2023 - Fault received from external node
Again, all three come back immediatedly. Anyone got any ideas? Milage is only 42k. The fuel rail pressure is 300bar at idle, is this normal?
Cheers,
Gareth
