josh19
Member Since 12 Jun 2012
Offline Last Active Jun 17 2012 02:24 PM
In Topic: Water Leaking Into Passenger Footwell
16 June 2012 - 05:06 PM
we checked under the dash and pulled out all the sound proofing ,then put a hose over the windscreen and let it run for 5 mins.
we then noticed a drip coming from the backing plate for the brake servo, so we unbolted the servo and spread sealer into the holes on the inside and around the servo mounting in the engine bay, it is now in the garage drying off will let it cure for a day or two and put the hose on it again. i`ll let you all know the results.
josh
14 June 2012 - 08:12 PM
cheers Pete will defiantly check that out, and Dan it would probably cost more than the car is worth haha :)
will be checking out all the seals and bulkhead if buying another ford!
13 June 2012 - 05:00 PM
hi dan, i take nit your talking about your 09 fiesta. mine is an 89 if they still leak 20 years later we haven`t got a hope of finding the answer any time soon :(
josh
