Member Since 17 Jun 2012
Offline Last Active May 04 2013 09:07 PM
In Topic: Fuel Filter Replaced, Now Car Won't Start
10 April 2013 - 09:13 PM
Sounds like there is air in the fuel system,If was fine before filter changed would guess there is a leak/pipe not on filter fully.
Go back to garage and get them to check it..
In Topic: 56 Plate Fiesta Tdci Problem
28 August 2012 - 08:17 PM
Cheap maf sensors dont tend to work very well.For some reason they work better on some cars than others but cant be relied upon..
Egr valves can cause rough running and loss of power and not uncommon to go wrong.
If its suddenly got very bad after you sprayed the maf sensor i think you just may have added to your problems...Can you borrow one from someone else for testing???
In Topic: 2006 Focus Engine System Fault
24 June 2012 - 09:23 AM
Hi, yes the flat battery does sometimes cause the error message on the dash. i had a battery on my focus that would just about still start the car but would give that message on the dash when it started. new battery and all was fine.
In Topic: Zetec S Foot Brake Pedal Travel
18 June 2012 - 09:06 PM
Well at least its not just my car then. Makes me feel a bit better about it. Would be nice to find a cure for it though..
