smokingmud
Member Since 26 Jun 2012
Offline Last Active Mar 24 2014 03:42 AM
In Topic: Factory Daytime Running Lights - Focus Mk2 Mk2.5, C-Max
11 March 2013 - 06:20 AM
Does anyone know the resistor value of this wire?
In Topic: Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
01 July 2012 - 05:24 AM
Yes Mulder add upto level 3 see if it displays then.
Do the test mode and see what version your HEC is mine is version V508, test mode meaning the Dash trick to scroll through HEC data , it might be that your HEC version is not high enough
Hi Preee,
I checked the ROM level is 0512.
Does it mean higher version?
30 June 2012 - 06:58 PM
Thanks Preee.
But which item is HEC data in Dash test mode?? Is ROM level?
Could you show me some pictures for me?
I think it would be useful for me checking.
Thank you.
27 June 2012 - 05:49 PM
Have you considered that it maybe your instrument cluster or ehpas module does not support steering modes.?
Like cruise control was not automatically supported.. Some models had cheaper modules from the factory which did not support cruise control.. Those aren't available from for dealers as spare replacements.. As dealers supply a 1 module fits all.. But in the factory to save a few pence they used different variants sometimes.. And if a car did not need a more expensive module they fitted the cheaper one.
Same is true of the instrument cluster.. The bottom spec model style? Which was dropped by ford had the rarer level 1 cluster, which was a single line LCD screen.. While most models had the larger screen..
Again things like DDS was only supported on level 2 instead of level 1
Hi RB2004,
Thanks for your suggestion.
Why do I so ensurely that my car can enable these functions because I knew many cars had done which the cars type is the same with me.
But I will try to enable it. I just need some help, that's all.
27 June 2012 - 05:43 PM
Hi
Try ELMconfig
HEC page 2 and add a couple of sub menu's see if it shows then
Hi Preee,
Do you mean the circle as below??
which submenu level should I tick?
BTW, there are some "Not used" items represent what??
Thank you.
