Thanks for all the help!
I have tested the plug and there is 12v coming through two of the connections relative to earth, but the light on the button still won't activate. Do you know which fuse/relay positions in the cabin and engine bay fuse boxes are needed, my manual doesn't tell me which fuses/relays are for the windscreen!
I played around with the rear screen, and found which relay governed it. I took out the relay and the light on the button still worked, but the heated screen did not come on. The same cannot be said for the front windscreen, as neither the light on the button or the screen comes on when the button is pushed, so it is more than just a single missing relay i think?
As for the radio, switching the yellow (battery) and red (12v switchable) meant the radio worked, but putting them back the other way also meant it worked for some reason? the radio would not turn on without the ignition in and twisted to the 1st position in either configuration, while the 6000CD used to...
All I need now then is the aerial adapter and the remote adapter then I am sorted with the CD player hopefully
I've had a look at the connections under the screen, Martin and stoney, and I cant see any damage to them. I understand that each half of the screen is separate and that they both earth on the drivers side pillar?
Thank you again for the help!
Rich
Find content
Not Telling
Latest Comments
More
