I have a 2004 Fusion 1.4 semi auto, bought new from Birmingham (Bristol Street Motors).
It always had a potential judder and knocking from transmission engagement if I didn't pull away in
a manner akin to tip toeing on eggshells.
Recently it lost the natural creep when moving slowly, and started to become a bit jerky or even "kangaroo" a bit.
My trusted garage recommended me to Steve's Autos in Blackheath, West Midlands UK, a little backstreet garage
on an industrial estate.
I had a transmission oilchange and new clutch at £500.
Oddly, the inside of the old bearing housing and bearings were ground away at a rough angle.
He told me all was fine and it was all set up and reprogrammed. He also said it would be a bit
sharp until it bedded in, which it was.
I continued to run it in, but it started to get drastically jerky, knocking on pullaway again and even
stalling.
He had it back in, and had an idea it was a duff mounting, which it was ; The thick rubber bush
inside the metal component was split in several places. It must have been like that since new.
Repair cost : £56 inc. part, labour and VAT.
Other owners with similar symptoms have been told they need new ECU's, actuators, new boxes etc,
one I read about with the same car was quoted £2000!!
Aparrently this is a common fault with these so look at the mountin bushes an components before
paying a fortune for other things
squirrelkeeper
Member Since 30 Jun 2012Offline Last Active Jun 30 2012 08:12 AM
Find content
Male
