Member Since 11 Dec 2007
Offline Last Active Apr 10 2012 08:55 PM
In Topic: Remove Cd Player
08 April 2012 - 10:59 PM
Above link is to my website - and thanks :)
Yes you can fit a sub to the standard stereo, after reading this post, I put another post on my website about this:
I have just made a video on how to remove the stereo here:
To wire the "High Level Input to Low Level Output" into your car, you will have to tap into the rear speark lines - these are the top two and bottom two most wires (coloured green&green/black and purple&purple/black) that come out of the ISO block:
Hope that helps
In Topic: Roof Rack Recess, No Holes To Screw Into
14 April 2011 - 01:00 PM
Sorted. It appears that Ford have filled over the holes with 10mm of filler which you have to gouge out with a screwdriver; underneath all this !Removed! is the hole. Great design Ford not.
This is to stop water leaks... make sure you plug the hole when you remove the roof rack, else you'll end up with a wet head lining
