minnis
Member Since 31 Jul 2012
Offline Last Active Yesterday, 10:49 PM
Bluetooth/phone Connection
15 May 2013 - 01:41 PM
Hi all,
I have a 2006 Mk2 Focus with the standard Ford 6000cd unit. I have already added an aux point which now works when I press the aux button. Now I also want to add some sort of bluetooth unit, and noticed the phone button on the stereo, which currently just appears to mute everything. Now is that its actual purpose (i.e, when you're on the phone, push the button so everything is muted so you can talk - but then why not just turn the stereo off?!) or is it for a bluetooth unit that was only installed in some cars?
Also, has anyone installed a bluetooth unit that they can recommend? I'm looking for cheap and easy too install as a top priority, as I wont be using it loads, its more to keep me legal.
Thanks in advance,
minnis
Engine Systems Failure 1.6 Tdci
23 March 2013 - 04:28 PM
Hi all,
My 2006 Ford Focus 1.6 TDCi came up with an engine systems failure message today just coming off of a dual carriageway (70mph) accompanied by a red light next to the trip computer. I think it went into limp mode (severly reduced power, unwiling to rev much), so not good when you live at the top of a hill! Two other times when starting the car it has briefly displayed an error message (once it said "steering assist failure", and yesterday it came up with the same engine systems failure message"). Both times I have restarted the car and it disappeared.
The car is a 2006 on an 06 plate, and has currently done 73500 miles. I bought it last may at 65000 miles, and it had a service just before I bought it. As it had just turned 6 years old/65000 miles, I'm presuming the DPF would have been changed then?
Does anyone have any idea what's wrong?
Thanks in advance,
Minnis
Whistling 1.6Tdci
15 December 2012 - 07:40 PM
My 2006 1.6tdci focus has developed a very high pitched whistle within the last mile or so. I have a recording which I'll post later when back home. The whistle started out of nowhere, and is always present. At idle, it is very quiet, and increases in both pitch and volume as revs go up. After about 2k revs, i assume its still there but engine noise takes over.
A quick Google search has suggested either a split pipe somewhere, auxiliary drive belt or the alternator. I opened the bonnet and, with the engine running, felt a warm draft in one place, near where a pipe meets the front of the engine. I'm unsure of whether this is normal or not.
Any ideas of what it could be?
Thanks in advance,
Minnis
Whistling 1.6Tdci
Thanks in advance,
Minnis
Focus Aux In Behind Glovebox
11 October 2012 - 02:14 PM
If the wire was indeed fitted, whereabouts would it be? I took my glovebox out earlier to find a mass of wires going everywhere. There were probably at least 4-5 different bunches of wires taped up going to different places in and around the fusebox. Where exactly would the aux-in wires be if included on my model? Thanks in advance,
Minnis
