ukd4v1d
Member Since 06 Aug 2012
Offline Last Active Apr 05 2015 08:45 AM
In Topic: Mk3 Retrofit Add Ons & Mods
05 April 2015 - 08:47 AM
does the continental version of the headlight have an adjustable shutter to convert from LHD to RHD?
Also can the auto level system be retrofitted? or is it too much like hard work
23 March 2015 - 11:38 AM
Well I was so determined for all of above, i traded my Zetec in and bought a titanium. Absolutely chuffed to bits, only thing I lost due to manufacturing date was Ford SYNC, but lets face it, it's not exactly a real benefit.
Only thing my Titanium doesn't have in Xenon's which I would like to retrofit. I am currently searching for some OEM Xenon headlights with ballasts and bulbs, but what else do I require to complete this mod?
I have the foCCCus program to be able to enable the Xenon's (as i have noticed it is an ECU option) but what else do I need other than the headlight themselves?
Really appreciate the Fantastic! reply from JW1982
look forward to some light shed on this :)
In Topic: Usb Compatible ?
06 March 2015 - 10:59 AM
Look behind glove box for bluetooth module wiring, will be taped up, a thick bunch of wires will go across the beam which runs dirctly under the glove box, loom will be taped up, quite large in size the connector so can't miss it.
If thats there you can fit the module and usb, if not you can buy a retro fit loom from ford but its around £160 + the actual bluetooth unit and the USB wire
Or buy a Parrot Kit
In Topic: Guide Fitting Cruise Control Focus Mk2 & Mk2.5 And Ford C-Max
19 February 2015 - 11:08 PM
I have just installed this on my 08 titanium focus, was a scary 20 mins sending the fw back to the car, but it all works as it should! Not bad only cost me £80 for all parts :)
