Member Since 08 Aug 2012
Offline Last Active Apr 24 2013 05:41 PM
Leak No More
24 April 2013 - 05:44 PM
well the dreaded injector leak is no more
not too bad a job just very very mucky
my advice .. in hind sight photograph everything  every nut bolt screw and wiring connector
also plug the injector clamp bolt holes while cleaning when  the injectors are out ... bits of rubbish down there are a nightmare to get out
all in all did it slowly over 3 days but the job itself is not that bad  :)
Ive Lost A Sensor Wire !!! Help
24 April 2013 - 02:38 PM
putting the car back together after fixing the leaky injectors and I seem to have lost a sensor wire
wondering if someone would be good enuff to trace it back for me so I can find it again
I think I have the right one going to the bottom of the airbox ( grey plug) but there is a sensor on top of the airbox that seems to have a vacuum  pipe running over to the timing belts but for the life of me I cannot find the wiring plug for it
however the grey plug wire is long enuff to reach the sensor .. so I am wondering if its the wiring at the bottom of the airbox i cannot find and if i have this one crossed over
can anyone help pls   :(
The Dreaded Leaky Injectors 1.4 Tdi Advice Pls
18 April 2013 - 01:40 PM
new to the forums
my mum has a 1.4tdi 2007
and its got the dreaded leaky injector fault
so I have it half way ( well more than that stripped down )
but the engine cover seems to be locked in firm .. all the bolts are out including the back ones
and I am a bit brute force and am a little worried I am going to damage this
now as I understand it it has the  inlet manifold o rings on it and I am assuming that this is whats locking it on
anyone any advice on how to free these up a bit or is it just a case of persistent rocking to get them off or something
has anyone got a trick to doing this
