Member Since 13 Aug 2012
Offline Last Active Oct 02 2013 09:52 AM
In Topic: Lowering Advice
23 September 2013 - 03:39 PM
all depends how precise you want it. obviously if you've lowered it,the camber will be out of recommended specs. how much have you lowered it?did you put lowered shocks on it as well?
Cheers for the reply.
I only lowered it 30mm, apparently you don't have to change the shocks as ford use the springs on the sports version of the mondeo, which use the same shocks as mine.
