Mr Singh
Member Since 18 Aug 2012
Offline Last Active Jul 22 2014 07:19 PM
In Topic: Focus Estate Drum To Disc Conversion Mk1 Estate 01
29 June 2014 - 03:55 PM
have you put the right calliper on the right side?
In Topic: Headlights: Driving Abroad
19 June 2014 - 07:06 PM
do you have projection lens headlights fitted? if so you will have a lever inside the headlight to flatten the flick to the left. if not then the stickers will do the same.
In Topic: 1.6 To 1.8 Engine Swop
14 June 2014 - 06:47 PM
dont forget to tell the DVLA of the engine swap
In Topic: Focus Mk2 1.6 115 Potential Clutch Problem?
08 June 2014 - 08:25 PM
our clutch is around 80% on top, just covered 80k, 2008 1.8tdci. pulls fine no slipping.....
try booting it from 1 gear to another, if it picks up straight away (kinda snatches) its fine.....
my mate tried that with his brothers impreza and he said that the clutch didnt slip. i told him to put it in 5th at 30 and floor it it slipped
07 June 2014 - 09:05 PM
OK, what's the best way to test for a slipping clutch?
best way to check for a slipping clutch is to put it in 5th at 30 and floor it. if the revs rise faster than the speed, the clutch is knackered.
