Mr Singh
Member Since 18 Aug 2012
Offline Last Active Sep 26 2014 06:04 PM
#372327 Very High Fuel Consumption, 1.6 Petrol Ford Focus 08 Zetec Climate 116 ..
Posted by Mr Singh on 07 June 2014 - 08:28 PM
Sniff around the fuel filter, and see if there is any small leaks from there. Depending on the age and quality of the fuel filter, it could well be a place for a leak.
no fuel filter fitted to the ti-vct engine.
i say stop being tight and tank it and then see what your getting. my mums saloon gets 27-30 MPG round town and a tank last about 300-325 miles
#360449 06 Ford Focus Mk2 Welcome Lights
Posted by Mr Singh on 05 May 2014 - 12:44 PM
I Have Already Tried That And That Works But Im Trying To Get My Lights To Come On When I Open My Car, Do You Know How To Do That ?
headlights or interior lights?
i don't quite understand and its quite difficult to read when you use a capital letters at the beginning of every word
#360065 06 Ford Focus Mk2 Welcome Lights
Posted by Mr Singh on 04 May 2014 - 03:55 PM
pull the indicator switch towards you as if to flash your main beam.
they are more of a 'guide me home light'
#332740 2008 Ford Focus
Posted by Mr Singh on 15 February 2014 - 05:30 PM
what problem are you on about?
#324378 New Alloys, Cleaner, Sealant Etc
Posted by Mr Singh on 21 January 2014 - 08:48 PM
i think i polished and sealed my wheels before i had the tyres fitted
#322511 Does An Electronic Fuel Pump Have To Be "primed" Before Installation?
Posted by Mr Singh on 16 January 2014 - 07:43 PM
hey! Give me a break will ya! Im a novice... LOL
break given :D
#321683 Does An Electronic Fuel Pump Have To Be "primed" Before Installation?
Posted by Mr Singh on 14 January 2014 - 07:52 PM
I know the oil filter has to be primed
say again?
#321680 Fog Lights - Only Legal In Fog?
Posted by Mr Singh on 14 January 2014 - 07:49 PM
there is another thing i dont understand, why do some drive with there side lights on and there front fogs? i mean dip beam gives a better view of the road than just side and fogs... and if you have a look as the light stalk on Honda's, Toyota's, Peugeot's for example there fog light switch is ON the stalk itself and not a separate button on the dash so when the driver switched there lights on, there fingers catch the fog light switch which results in the fogs being illuminated.... same when the fog lights are switched on genuinely the rear is switched off when the lights are switched off but the fronts stay on.
they are called FOG lights for a reason...  :angry:
incorrect usage of lights in a PROPER pet hate of mine, right from no lights when its dark to only using side lights (even some cases of no lights) when its foggy.
#309380 Dpf Removal To Fail Mot In February 2014
Posted by Mr Singh on 06 December 2013 - 06:00 PM
i say its a good thing... it'll teach driver to buy a car which is fit for the type of driving they do.
#284802 Engine Swap
Posted by Mr Singh on 24 August 2013 - 07:51 PM
well will need EVERYTHING from the donor car from the engine bay. you will need the engine, gearbox, drive shafts, ECU, wiring harness, possibly keys, new hubs and brakes if the engine is from a different car.
#284151 V-Power Nitro+ And Unexpected Side Effect
Posted by Mr Singh on 21 August 2013 - 05:27 PM
I'm lead to believe they are phasing out standard V-Power altogether in favour of the Nitro brand....?
same shizzel different name in my mind.
you should see me on the smart forums... new owners not getting the name of there cars correct e.g. fourfour, fourtwo.
#283922 V-Power Nitro+ And Unexpected Side Effect
Posted by Mr Singh on 20 August 2013 - 06:50 PM
Hi guys.
This is a bit of a strange one this............
I thought I would try using V-Power diesel in my new car (only had it a month) to see if I could notice any benefits over supermarket fuel as in smoother engine, increased MPG etc etc
I accidentally put something called NITRO+ in by accident as I didn't realise Esso did anything other than just V-Power.
Gutted when I had filled the tank (extra 8p per litre) :(
didnt realise that esso also sold V-Power nitro+... i always thought it was only shell?! :D
V-Power changed to V-Power nitro+ around febuary march time.
#282168 Ford Tensioner Crazy Price-Wowcher!!!
Posted by Mr Singh on 13 August 2013 - 06:45 PM
ford were ACTUALLY coming to the jaguar dealer in leeds to buy the release bearings as they were cheaper than theres
#278219 Headlight Lenses.
Posted by Mr Singh on 28 July 2013 - 08:04 PM
try some toothpaste. i tried it on my forfours headlights and it improved the scratched on them
#276996 Adaptive Headlights
Posted by Mr Singh on 23 July 2013 - 03:34 PM
one of the bulbs went on my mums focus, so i remove the headlight and see a spare unused connector, is that the connector for adaptive headlights?
i havent noticed it on my uncles focus which is a few months newer than my mums
