Member Since 20 Aug 2012
Offline Last Active Jan 22 2013 09:39 PM
In Topic: Black Smoke
16 October 2012 - 07:34 PM
If u blank egr does this not leave engine check light on all the time on euro 4.?.
I had my vacum regulator go faulty which gives same effect as blanking egr and light stayed on
In Topic: Fault Code Help Please
07 October 2012 - 11:54 AM
I'll try that when I get a chance Sony do it any harm.. Maybe also worth mentioning I have a code p1000 as well.. Would it be possible that this p1000 code is stopping the light form turning off as egr maybe hasn't done a full drive cycle as ford talk about...
07 October 2012 - 09:19 AM
i havent but after a bit of research this morning i was thinking of doing that as in my head thought maybe valve is operating correctly but if manifold is clogged up the flow of air may not be suffient in turn puttin on the engine light..might try taking it off later today...have you ever done this before?
06 October 2012 - 04:12 PM
Ok just tested sensor in both old n new egr valves both read 1.5 volts closed and 4.5 volts open..
Is there something I'm missing that's causing this fault... Really drivin me mad
06 October 2012 - 02:37 PM
Yes replaced egr but no difference..I wouldn't know what values to be looking for at the egr 3 pin plug.. Would it be possible the maf sensor is faulty
