Member Since 20 Aug 2012
Offline Last Active Jan 22 2013 09:39 PM
Near Side Rear Rattle
22 January 2013 - 09:39 PM
I have a rattle in my near side (pass side ) rear corner.. I had a had quick and seen straight away anti roll bar bushes were well worn so suppose jumping the gun said to myself there's my rattle..
Any how new bushes now fitted and still have a rattle in near side rear corner..
What's the best way to check subframe bushes and also can anyone give me other ideas as to what this can be..
Should maybe mention that It only seems to be there when drivin over a rough uneven surface.. For example a cobble road like you'd see on coronation street..lol
Is This Normal.?.
16 October 2012 - 07:41 PM
Hi recently bought a mk3 Mondeo tdci euro 4
I'm having problems with excessive black smoke when accelerating away from a stop and also when car is under load.. ie if at approx 25-30 mph in 4th gear and go to accelerate I get a trail of black smoke.. If I blank of egr this issue goes away.. Had thought egr was stuck open but with using f super and the live data feature the egr is opening and closing as it seems it should..
Any thoughts..???????
Anyone Any Good With Wiring Info.. Asap Please
08 October 2012 - 07:43 PM
Hi I have an egr sensor fault and I'm wanting to look into the wiring of this sensor back to the ecu..
Sensor appears to be working correctly at the sensor plug although this does not rule out that the position signal wire returning to the ecu is not rubbed or broke this giving my check light on dash..
Could someone give me PIN numbers on the ecu from these 3 wires or if possible post a wiring diagram up...
Would be very much appreciated.. Tryin to slove this issue ASAP..
Scan Tool
07 October 2012 - 03:41 PM
I'm thinking of buying one of these super f scan tools..
Can anyone tell me are they any good and also when any faults codes are cleared I'm assuming any fault lights should go out and remain out or do some faults need to be driven to clear the fault..
Fault Code Help Please
06 October 2012 - 01:54 PM
Hi I have 2 fault codes which keep re appearing and it's drivin me mad..
Codes are p0405 and p0401
P0405 says exhaust gas recirculation sensor A circuit low
And P0401 says exhaust gas recirculation flow insufficient detected
I've have these cleared a few times only to keep reappearing have also tried cleaning my egr which didn't work and also tried a new egr valve which also didn't work..
Any help guys would be great I don't now much about the fords but its driving me mad.. By the way cars a 05 mondeo 2.0 tdci 130 bhp euro 4
