Member Since 24 Aug 2012
Offline Last Active Aug 27 2012 10:11 PM
Battery Out Audio Codes
24 August 2012 - 09:56 PM
In my ford handbook folder I have a key code card. It does have a four digit number written down. I have a touchscreen satnav cd/rad and I also have the DVD player for the rear seats, and the manual for that implies it needs a keycode if the battery is disconnected/replaced. In the old days, so did the main stereo. Would they be coded the same, or do I need to go hassle the dealer and get Ford Direct to produce a second keycode for the DVD system, or what?
Thanks in advance for any help :)
Usb Socket - What Do I Use?
24 August 2012 - 09:51 PM
I didn't find this either in the manuals or from a limited search of the forums :)
My Mondeo is a 2012 model with the touchscreen nav system and SD card maps. In the glovebox I have a USB socket and some sort of aux-in for ipods and that.
I want to use the USB option for loading files, particularly audiobooks, since I couldn't buy a 6CD changer like my old Scorpio had for this sort of function (they tend to fill several CDs).
My first attempt was a fail, I formatted up a USB connected 1TB hard drive as an EXT3 volume upon which I put some WAV and MP3 folders and while the Mondeo recognised there was something plugged in, it didn't find any files on it.
Is there a definition or guide as to what you can plug into the USB port, what format it should be in, etc? Does it need fat32? can it power hard drives? what are the limits on memory sticks?
I've gotten my phone bluetoothed up and it's pretty neat that it can grab tracks from that, although it seems to be random play rather than searchable (that might be my phone, of course.) Random order won't work for ten hours of unabridged audiobook, though, obviously. :)
