Member Since 26 Aug 2012
Offline Last Active Nov 21 2014 11:50 PM
In Topic: Mystery Connector Behind Glovebox
17 April 2013 - 12:49 AM
Good idea.... I'll look see if I can find confirmation either way...
In Topic: Hi Y'all :)
06 April 2013 - 06:06 PM
Welcome to the club pal
Ta :)
06 April 2013 - 05:42 PM
Welcome to the Forum John.
Nice modification mate, not fun swapping ends on a roundabout is it?
Ta :D
Not fun at all, I've had the back end step out before when I've hit potholes when cornering but I've always caught it before I'm facing the wrong way... this time it was way too quick all I could do is hang on and hope.
Managed to get most of the dent out (piece of wood and a rubber mallet), just needs a rub down, little filler and a respray.... waiting for summer as I don't have a garage... we might get a sunny day this year..
In Topic: Gears Not Engaging - 04 Fusion 3
05 April 2013 - 11:53 AM
I sometimes have problems shifting into reverse (feels like it's in but you just get gear grind when you let the clutch up) but on Wednesday when I was leaving MOT centre (just needed a tyre and a backbox :) )  I reversed out and couldn't get 1st to play ball at all, tried a few times then shifted back to reverse, backed up a bit, then tried 1st and it worked this time.
Sorry I can't help with a solution, not had the problem before or since, I will probably leave it unless it starts doing as often as the reverse problem.
