Member Since 29 Aug 2012
Offline Last Active Sep 24 2012 09:36 PM
In Topic: Possable Solutions To The Fashing Orange Light Of Death!
24 September 2012 - 02:19 PM
a friend of mind has suggested that i get my injectors checked and if need be, recoded/replaced as I've done over 180k.
not only do i get the flashing glow plug light, but i also have an engine light that comes on with the fuel warning light when low on diesel!?
*try keeping your revs bellow 3,100. I've found that stops the limp mode from activating on mine .
In Topic: Strange Clutch Slip?
29 August 2012 - 09:49 PM
that's what i thought... but I've just read about identical faults on another post and i think its going into limp mode?
In Topic: Does Anybody Know ?
29 August 2012 - 09:43 PM
how you getting on with your fault? my mondeo is having exactly the same problems that you've listed?
In Topic: Help Glow Plug Light Flashing
29 August 2012 - 06:48 PM
hi fella.
did you get the flashing glowplug light sorted?
I've got a 53' 2.0 tdci 130 and having the same problem. so far I've narrowed it down to faulty glow plug, faulty injection (or injector control module.), fuel filter (or fuel pump) or the egr value...basically it seems it could be pretty much anything!
i have found that i occasionally get the engine light flashing on for a few mins? no loss of power and turbo works? (although the clutch slips at 3500+rpm but pulls away lovely) [will be posting this problem].
