teecee90
Member Since 09 Sep 2012
Offline Last Active Mar 03 2013 05:50 PM
In Topic: Does The Front Subframe Have To Be Re Aligned After Clutch Replacement
09 January 2013 - 10:23 PM
When my clutch was replaced the subframe wasn't fully removed - just lowered enough to remove the the gearbox which was then rested on the subframe while the clutch and flywheel were replaced. It was then refitted without the use of any pins and has been absolutely fine. It was done at a specialist clutch and gearbox centre - the fitter had obviously done it many times before and mad very short work of it. Sounds like yours has been a bit of a cowboy job - where did you take it?
In Topic: Diagnostic Equipment
16 September 2012 - 07:44 PM
I have the F-Super. Many AV programmes throw out a false positive virus warning for the Formidable software. Its best to turn your AV off before installing the software and then re-enable it.
I don't think it programme your injectors though - I think it only works on post 2004 cars, but I may be wrong.
