Hello all.
I have a 2004 Mondeo TDCI 2.0 130. I’ve driven about 3000 miles since buying it with 126,000 on the clock. When I bought it I took a risk that the black smoke on heavy acceleration would not ultimately cost me dear because for the age the bodywork and inside were both in pretty good condition and the road test of about 40 miles went very well.
Apart from the smoke the only tiny niggle was that occasionally it didn’t start first time and occasionally it took a few seconds after starting for the power to be there. The car ran very well generally and it was a pleasure to drive.
Recently, after 150 or so trouble free miles that day I was slowing down on a motorway slip road approaching a roundabout. I could feel a very slight juddering. It was so slight I couldn’t decide if it was the engine or rough road surface. When I stopped at the roundabout it cut out and was difficult to start. I managed to get it to crawl over to the hard shoulder. It started with difficulty and ran very roughly.
An RAC patrol man diagnosed loss of compression. I had the car towed to a garage local to my home which I’d used a lot for my previous car and felt I could trust them to do a good job. They rejected the RAC diagnosis and said the problem lay with the diesel injectors. They recommended getting them tested by a specialist at a cost of £15 plus VAT each. They warned that 9 times out of 10 if there was an injector problem all 4 failed. This struck me as odd. I approved the testing as I felt I had no option. The recommendation of the specialist was to recondition all 4. My garages quoted £936 for all the work involved. I decide to go ahead. While this was on the high side they had my trust and that was worth something to me.
After refitting the injectors the engine still wouldn’t run properly so the car was sent to the specialist which reconditioned the injectors. They checked their work and claim it was necessary and was done appropriately. The car is back with my garage and I’m trying to decide how to handle this.
Have any of you any advice? Was it a reasonable thing to do to suspect the injectors and do £936 of work on the basis of this suspicion? Should other cheaper things have been tried first? Could all four injectors have failed at the same time and caused a sudden problem such as I had and for there to be simultaneously another fault?
Your help would be appreciated very much.
IanInHerts
Member Since 16 Sep 2012Offline Last Active Jan 21 2013 06:12 PM
Find content
Not Telling
