Member Since 21 Sep 2012
Offline Last Active Feb 28 2013 01:36 PM
In Topic: Modification Projects/general Modification Discussions
28 February 2013 - 01:36 PM
Hi Ford Fans, please help. I am driving a 1993 Ford Sapphire, 3.0i v6. It is fitted with a Lucas 5am air flow meter. The problem I have is the plug that fitted onto the meter broke, so I just cut it off and attached the wires directly to the connectors of the Air flow with clips, its making contact, but I have a feeling they are not correctly, the throttle pos you adjust for the idle speed is not responding as it did before. There are 5 connectors on the air flow meter. from the left side there are three then a gap and then two. There are many posts in various other forums with the wire color and connector it must connect too, but my wires are completely different.
My wire colors are as follows: Brown with trace Black, Brown with trace Grey, Black and Brown with trace Red.
So, in short, which wire connects to which pin.
Any help would be much appriciated.
In Topic: What Engine Is In My Ford 3.0Irs
22 September 2012 - 03:28 PM
Hi Bruce, thanks for the info! I have been doing some research and it would seem it is a 3.0 v6 6 cylinder engine with EFI.
I wonder if there was ever a workshop manual that was ever produced for this.
