aps67
Member Since 21 Sep 2012
Offline Last Active Mar 21 2014 10:21 AM
In Topic: Sony Dab Radio Upgrade
25 February 2014 - 05:10 PM
Ive recently upgraded my Sony MP3 fac fit to a DAB version , read all the info regarding changing aerials etc etc
I bought a magnetic mount aerial off fleebay and it sits in the boot (foor) and gives me spot on reception !
Well worth the £11.99 inc delivery !
The aerial sits on the boot floor to the right corner so clear of anything , sticks through the hook eye hole in the carpet and is only 5" high !
Just another thought if your interested .
In Topic: Steering Wheel Controls With Aftermarket Gps Help
08 May 2013 - 04:25 PM
Further to this adapter thingy i need , ive been searching around & it looks like they are freely available for "brands" such as kenwood, sony,pioneer etc ..
Has anyone used or any knowledge of them at all (adapters) ?
thanks again
07 May 2013 - 06:15 PM
Dont get me wrong , i really do like unit , it works near pefectly apart from the pesky stalk controls...
Everything else is spot on really ..
BUT i do miss the remote control from the stalk.
Now of they made one which is DAB then that would be perfect.
cheers
07 May 2013 - 05:57 PM
Good stuff James , any ideas on where i can one at all ?
Im assuming then itll just be a loom in-line type of affair .
cheers
07 May 2013 - 04:27 PM
I only removed it to test , it doesnt work either way.
I read somewhere that my "control" is analogue therefore did not need the canbus box.
When i press the test in the steeringwheel setup on the unit it displays the values : 255 / 255 or something like.
But when i attempt to program the unit with the stalk controls i get nowhere with the canbus box in situe.
is it correct that removing the box is the right thing to do , you see this is where it confuses the whatever out of me .(by removing the box its simply a plugin to the loom thing)
Should it work without the canbus box right away with no splicing of wires etc ?
Should it work with the canbus box with my spec of car right away ?
cheers
