Hmm rather a lot I suspect.! The cylinder at the other end is inside the gearbox housing. Normally if changing the cylinder you would change the clutch. \if you're changing the clutch you need to change the dual-mass flywheel(this may be the cause anyway). Lokking at £500-£650 or much more at main agent I'm afraid.
£595 - you were almost spot on!!!!!
Find content
Not Telling
Latest Comments
More
