DFance
Member Since 28 Sep 2012
Offline Last Active Oct 30 2012 11:17 PM
In Topic: Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
30 October 2012 - 11:07 PM
You might want to try plugging usb cable into laptop first, open software, then plug elm cable into car...
30 October 2012 - 10:34 PM
Hello All,
I've got a lead and modded from the guide with a switch.
I plugged lead into laptop and drivers installed.
Then I went to car plugged lead in
pligged lead into laptop
ran ELMConfig.exe selected english
selected com1 from port drop down and 38400 and clicked open port
I receive error:
What am I doing wrong?
Also when do I have to actually use the switch? Do I plug into car in centre position?
Many thanks
Are you turning ignition on? Don't start engine but set to turn your dash on...
You use the switch to work between two different levels of CAN...ms can is one switch, hs can is the other...you can see which level of can or switch position as you look at the ELMConfig software.
Hope that helps.
