Taipan
Member Since 29 Sep 2012
Offline Last Active Private
In Topic: Fiesta 1.4 Tdci Only Cranks Over For Approx 2 Seconds??
14 January 2013 - 03:34 PM
I found this which is basically there is a update for the PCM.
http://www.locostbui....php?tid=101124
Wife's derv burner 1.4 TDCI Fiesta,
Is refusing to start first thing in the morning.
Chain of events.
Key in to pos 2 ( all lights that should come on come on and then go back out ).
Turn key to start ( starter motor tuns for a couple of seconds and then stops )
repest these step a couple of times and she will finally start.
Battery seems in fine shape ( bit I will check tonight )
So a couple of questions
1 even tough the 1.4 is a direct injection does ot still use glow plugs ?
1a if so any idea what resistance I should be getting
1b do the glow plugs always come on or are they temperature dependant ?
2 do some moden ( this one included ) cars have a starter time limit to stop overcranking and over heating the starter motor ?
Anyone have any other ideas ?
regards
Agriv8
I took the car to the ford specialist today, only there for about 30mins.
He plugged a laptop into the dashboard,ran a complete diagnostic test and found no errors,but after a few mins discovered there was an update available for the engine managements.
I think it was called COLD START DRIVABILITY.
So he updated the PCM calibration files and reset the parameters.
It cost £45.00.
under a Ford 1.4 TDCi Starter motor Cut out.
Wonder how much the main stealer going to charge. I will give them a call.
Agriv8
edited to add it seems that post 54 reg have the updated EM map from new I suspect I will find ours needs updating
14 January 2013 - 01:16 PM
Fairly recent battery and it will spin it over quick enough. This isnt like a failing battery, its more the power to the starter is interrupted for some reason. I'm guessing its temp related as its fine when its warmer?
In Topic: Noob With A Couple Of Questions
01 October 2012 - 05:50 PM
Thanks for that. The spare is a 175/65x14 and the car no longer pulls with the right alloy back on there.
01 October 2012 - 02:48 PM
I think you're right as the edge of the tyre is worn. Think i'll get it tracked just in case.
01 October 2012 - 02:20 PM
Top man, thanks.
