glyndwr
Member Since 14 Oct 2012
Offline Last Active Mar 04 2013 05:49 AM
Cigar Lighter // 12V Charger
03 March 2013 - 10:03 AM
hi all i have a st170 focus 52 plate the 12v charger not working iv checked the fuse it seems ok ????? any ideas please Attached File  512bc05147af7_1.jpg   35.11KB   20 downloads
Cutting Out ??????????????????????
10 December 2012 - 04:26 PM
my 2003 tdci mondeo cuts out ,, as soon as glow plug starts flashing engine cuts out happened last Thursday doing 80 mph on way to work (scary ) then AA came out told me cam sensor so they replaced it then Friday night on way home from work again cuts out got recovery to garage ,, today cut out again ?????? garage could find nothing ,,, now gone to ford dealership to look at ,, not looking good :( :( :( :( :( :( :( :( :(
Chip Fat
14 October 2012 - 06:12 PM
just wondering could you run a mondeo tdci mk3 off cooking oil ???? ;) ;) Attached File  m.JPG   226.49KB   43 downloads
How To Identify Euro 3 Type Euro 4 Type Below
14 October 2012 - 11:09 AM
How to identify EURO 3 type EURO 4 type below
If the vacuum type valve has one electrical plug on it, then it should be treated as a Euro 4
Note the piggy back motor, and it should not be unplugged when the plate is fitted
When EGR valve sticks open air supplied to engine by turbo above 1800rpm is diverted into exhaust pipe by stuck open EGR valve, engine management system thinks all this air is going into engine (detected by MAF mass air flow sensor which is located near air filter outlet) so EMS injects fuel to match air it thinks is going into engine, this results in too little air and too much fuel which = Black Smoke.Fitting blanking plate blocks air going back to exhaust so all air boost from turbo goes to engine to burn with fuel. Also stops exhaust going into the engine, which also makes it smoke, and lowers fuel consumption.
Sticking Temp Gauge
14 October 2012 - 06:53 AM
Hi just wondering if anyone can help , my 2003 mondeo tdci temp gauge sticks halfway i turn engine off stays there , i then tap dash a few times needle will then drop , turn key in ignition needle will bounce straight back to halfway point ,, i phone local ford dealership was told needs new cluster at cost of £435 plus vat and labour ,, any help please im hopeless with these things .
cheers martin
