Support the club!
jimmygixer
Member Since 19 Oct 2012
Offline Last Active Jun 06 2013 11:37 PM
In Topic: Springs Or Shocks?
06 June 2013 - 11:41 PM
This will be most likely caused by broken springs - not uncommon im afraid
I checked earlier on and the springs are intact. I did notice before i got two new tyres on the front today that the fronts had been 215/45/17 and not the same as the rear which were 215/40/17's.
So i changed them to 40's hoping that is what has been causing the slight rubbing of the inner liners.
In Topic: Notch In Steering
26 May 2013 - 02:06 PM
i cant remember exactly what happens but its in the bowels of the rack a few on here had it in the past and you tubes full of vids with it the only fix is the rack has to be removed and replaced its not fixable it does happen suddenly and it does happen only in one direction its a well known issue on the early focus im afraid
Ok, cheers.
25 May 2013 - 10:04 PM
The steering rack needs replaced its a known fault theres no way round it as it will get worse sorry to say
 Do you know what actually happens to the rack, is it general wear on a particular part?
It seemed to happen all of a sudden with no gradual increase before i noticed it, and only in one direction?
In Topic: Crap Handbrake
15 April 2013 - 10:49 AM
if you can, jack up the rear of the car - preferably both sides at the same time. Ensure the car is in gear first though
Release the handbrake and make sure both wheels spin freely - if they do then fine
Next apply the handbrake until it goes tight as normal and check that both wheels are locked tight
Will do, thanks.
Just waiting on the weather for it :(
14 April 2013 - 10:21 PM
Disc brakes are pretty much self adjusting so i think you need to look for a sticking or lazy caliper to be honest.
I will give them a look at and see.
