mrdavidpickup
Member Since 23 Oct 2012
Offline Last Active Oct 24 2012 07:13 PM
Mk1 53 Plate C-Max Gone Into Engine Idle Mode
23 October 2012 - 04:38 PM
MK1 53 PLATE C-MAX 2.0l TDCI ZETEC
No Engine warning light illuminated
Engine in idle mode and not going greater than 3000rpm
Have disconected negative terminal on battery and reconnected after approx 15 min, this seemed to clear the issue as engine then proceeded to go higher then 3000rpm however same issue happened about 1hr later, no warning light but engine in idle mode after being switched off
Someone has advised there is a way of putting the car into a "self learning" mode however im unsure how to do this.
The car is not ODB2 compliant so am unable to attach code reader to see if any faults.
Does anyone have any hints, tips or suggestions?
