Member Since 24 Oct 2012
Offline Last Active Feb 07 2015 09:02 PM
In Topic: Mk2 Xenon Headlamp Retrofit
25 August 2014 - 08:56 PM
If you can't see I'd recommend taking the trim off and peeking up as you may be able to see it better...
I take it you don't have xenons yet your just looking to see if your able?
What trim spec are you?
18 August 2014 - 06:09 PM
I've told you that one already mate and if you've bought a keyless entry loom you will need a keyless engine loom too otherwise the signals will not go from start button to the body control module (ecu I'm the boot) to the pcm. The pats will also not function as it's a completely different system. The keyless entry uses the body control module whereas the normal standard ignition you had uses the instrument cluster. Look at the wiring schematics given to us all by Pree and you'll get the idea. You'll need to change a couple of options with elm config and also add some additional keyless remotes so they can read by the pats...
Even though it seems these cars are built like lego you need to be aware that's it's not always a simple case of changing some wires and it will magically work . Change one and you need to change all - then program it.
13 August 2014 - 07:42 PM
The start button will not work mate that part comes from the keyless entry module so you'd need that and main body loom....and you'd have to modify your engine loom to make that extra push start connection.... And also program it all with elm config
I'd put the original loom back if your looking for a sell and just stick taking the wires in the rs loom that you need
11 August 2014 - 10:56 PM
So you have ignition it just doesn't crank? You haven't added any other rs parts have you? Just the loom? Rs was also push button start so if you haven't added the wires into the loom it could be missing the wire direct to the start relay to your connecter should be red from memory I'll look at mine tomorrow and upload some pics just to be clear as I had this problem too
11 August 2014 - 10:31 PM
Take a picture of your set up fella both the starter and the connectors there should be 4 wires
