Managed to rectify problem now. Took drivers door panel off only to be confronted by another panel underneath to which the electric window motor seems to be attached to. Rather than spend ages removing all this , I simply cut a hole in this panel so I get my hand in to pull wires through that pass from bulkhead to drivers door. On inspection I discovered a broken wire. Simply reconnected it together using a bullit connector. These wires take a lot of punishment with the constant opening and closing of door. So I suspect I havent seen the last of this problem.
Had already tryed that to no avail. Removed fuse F34 though which sits imediately below it(according to fuse layout diagram printed on pull down glove compartment F34 is for electric sunroof which is not fitted to this car. This has disabled the central locking. Hope it has'ent disabled anything else! Jury is still out on that one. Thanx
