Hi I am having a bit of an issue with the reverse lights and sensors on mine at the moment. They are just popping the fuse almost straight away. Just wondering if anyone else has had the same problem.
Fusion 1.6 Diesel 57 Plate
Ford fitted elec pack with Reversing sensors
If i fit a new fuse and then put it into reverse, it will beep and the lights and sensors will work. After driving somewhere, if i try it again, it will have popped the fuse.
My first thought is to disconnect the reverse sensors and see if that solves the problem so if anyone has any knowledge of where the wiring is connected to the loom or where the little box of tricks is installed, i would be grateful
Pete
peteandem
Member Since 04 Nov 2012Offline Last Active Nov 04 2012 08:25 PM
Find content
Not Telling
