- → Viewing Profile: Posts: Kory-ST90
Support the club!
- Group Members
- Active Posts 11
- Profile Views 146
- Member Title Member
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Not Telling
Ford Model
Bantam Rocam 2005
UK/Ireland Location
Other/NonUK
0
Neutral
User Tools
Friends
Kory-ST90 hasn't added any friends yet.
Latest Visitors
In Topic: Focus Making Funny Noises Whilst Idling
06 November 2012 - 10:58 AM
While its idling push the clutch pedal down if the noise stops its the clutch releaser bearing its a common thing on fords to sort this problem out the guys put thicker gearbox but this problem is normal and nothing to worry about
In Topic: Please Needs Some Massive Help!
05 November 2012 - 10:58 PM
Yeah sounds like your releaser bearing on the clutch its a common thing and ford says it normal anyway by putting thicker gearbox will cure this problem and yes take the car to diagnostics
In Topic: Coolant Leak
05 November 2012 - 10:44 PM
Sound like head gasket if the car is smoking bad you should not use the car as water will mix with oil and cause serious damage
In Topic: Mondeo 1.8 Petrol Lx Stuttering On Acceleration
05 November 2012 - 10:38 PM
Hey pete I have the same problem also but this is normal as ford use the old cable root but adjust the acc cable if it is loose
05 November 2012 - 10:35 PM
Sound like your coil pack bud but do a diagnostics to see
- Privacy Policy
Find content
