Neo222
Member Since 05 Nov 2012
Offline Last Active Nov 08 2012 09:55 PM
In Topic: 1.4 Diesel Ford Fiesta Titanium (2009) Beeps When Ignition Is Switched On. Help?
08 November 2012 - 09:15 PM
Yeah it doesn't really sound like any of the others, just popped out and had a look and there are not messages either.
08 November 2012 - 08:17 PM
Ran a diagnostics/fault check with a ProScan V580 and it showed up with no errors :wacko:. Any ideas what I should do now or what else I could check. Also on an extra note if I turn off of warning chimes it doesn't beep when the ignition is on but instead beeps when I turn the engine on.
08 November 2012 - 01:52 PM
Thanks for your replies. I was only given one key when I bought the car, and I wasn't told anything about it having a tracking device installed. If it did would there be a way of checking apart from the beeping?
Is this problem likely to be show up when a diagnostic tool is used to check for errors?
Thanks again
