i got some very cheap prongs of ebay 1.98 all in did the job . the 2 on the right seem to lean to the wright , the one in bottom left leaned to middle the one that slides in where it says cd you need to apply gentle force the pin pushes a metal spring back it makes a s slight noise and resistance then it clicks when its in far enough . pull the 3 other prong lever them back to they are all the same possition as the one in top left and a gentle pull out the unit . when you put the unit back i found if you take the 2 pins out on the left hand side out . and insert the unit push the 2 right hand pins to the right and pins come away with a little wiggle . i am a novice but did ours today. allenThanks for the tip about the way the prongs go in.
I'm expecting some tomorow and didn't know that.
Update.
Went fine.
Would have been lost without the tip.
morphious76
Member Since 07 Nov 2012Offline Last Active Nov 08 2012 04:08 PM
Find content
Not Telling
