Member Since 08 Nov 2012
Offline Last Active Apr 18 2014 07:54 PM
#223185 Ford Focus Mk.2 Estate Boot Water Ingress
Posted by jon-v8 on 28 December 2012 - 08:03 PM
Have you check the foam seal on the rear of the light clusters?
I had the same issue with my estate, I found that the rear cluster wasn't fitted correctly at the dealers - they trapped wiring loom between the cluster and the pillar (not tucking the loom into the pillar correctly), this then allowed water to get into the boot and fill up the small box section in the corner. Mine eventually overflowed into the wheel well!
My fix (So far it has worked), was a couple of beads of silicone around the cut out on the rear pillar, allow to dry and harden and re-fit cluster.
