good old reliable
Member Since 12 Nov 2012
Offline Last Active Mar 06 2013 09:00 PM
In Topic: Vibration When Driving Under Load Mk1 Focus 1.6
26 February 2013 - 07:10 PM
ok update on the vibration thing.
found two of my alloys we slightly buckled,!! had new tyres put on all of them and no one said anything.
this is how i found out, but not saying you do this.
jack drivers side wheel up, hand brake on other wheels chocked, traction control off.
put in 4th run speed up to 35mph got slight vibration in the car. took it up to 50-60mph the car vibrated like hell.
swapped other wheels for the same hub and found 2 wheels no vibration but another slight vibration.
took wheels to garage and they checked wheels again and found my wheels were slightly oval.
changed for another 2 wheels had them all balanced again and the vibration a lot better but still slightly there.
13 February 2013 - 07:16 PM
ok changed mount
small splits both sides but nothing major thumping still there also vibration
i have had the car for 11 years now so no boy racer there! lol.
i did how ever when checking things found fair play in n/s driveshaft when twisted backwards and forwards can hear gears in box knocking.
i also have thumping when going over uneven road sounds like coming from front suspension somewhere??
In Topic: Mk1 1.6 85,000 Miles
06 February 2013 - 10:23 PM
had a good poke around tonight only thing that i could move was the rear lower arm bush
the other thing i noticed was both lower ball joints rubbers had split there was no movement in them yet?
06 February 2013 - 10:18 PM
ok up date
checked rear engine mount to chassis no movement back forwards only can move end on engine side to side a bit.
checked engine mount on drivers side no movement
checked gearbox mount on passenger side can't move the engine but when put screw driver down between body and centre mount there is quite a bit of movement. the mount seems to have cracks and splits on either side. the mount only seems to be joined left and right side with kind of bump stop at the rear i suppose to stop engine moving backwards too much is this right?
could this cause kind of like thumping when moving very slowly in traffic and you lift the clutch up a bit quick and when the clutch bites hits i hear a thump....
04 February 2013 - 07:51 PM
Do i replace them or can i just tighten them?
