Member Since 14 Nov 2012
Offline Last Active Nov 15 2012 09:22 AM
2006 1.6 Tdci Fuel System Problem
14 November 2012 - 06:25 PM
Hi, new member here. I drive a 2006 Ford Focus van, 1.6 TDCi engine.
Having some problems for the last 6 weeks or so. The revs dropped in the van while driving, and it eventually turned off. Similar to if the van had run out of fuel. Eventually got it going again but the problem continued. We removed one of the injectors and found that there was no diesel going to it, it was dry. We dropped the fuel tank, but found that there was no pump within the tank. So we removed the high pressure pump and replaced it with another one. That worked for a day before the car stopped driving again. Then it would drive for a while and stop.
Then, after a week or so of driving perfectly, we put it on a diagnostics machine to clear an earlier fault (under boosting turbo). But when it came back from the main dealer's garage it stopped driving again. We then decided the problem must be the injectors, so we replaced all 4 of them and replaced the map air sensor while we were at it. But the problem still isn't solved. I was wondering if anyone else has had a similar problem or knows of any other solutions. Maybe it's an electrical fault which is stopping the injectors from operating? Any help would be greatly appreciated as the cost & time period of the job are constantly getting bigger.
Thanks in advance,
Just An Introduction
14 November 2012 - 06:11 PM
Hello, just a quick introduction.
I drive a 2006 Ford Focus van, 1.6 diesel. Having some trouble with it, thought I might be able to find some answers here. The problem seems to be based around the fuel system. I'll start a new topic in the apporpriate section if any of you would like to help out.
Thanks, Jamie.
