Alexsimpsn
Member Since 19 Nov 2012
Offline Last Active Dec 14 2012 05:25 PM
Mk1 Ka Failing To Start
19 November 2012 - 06:04 PM
Hi all, new on here but I've been on as a guest quite often looking for advice :)
my problem is this, The engine will turn over, fail to fire and cut out. also whilst cranking it if you even so much as touch the throttle it'll make this god awful sort of grinding noise and immediately die. any clues?
recently had to change the thermostat housing as the old one ruptured and leaked coolant everywhere (this of course caused it to overheat and cut out at the roadside).
also recently replaced the plugs and HT leads as the old ones had corroded causing misfiring, but this was at least a month prior to the coolant issue.
oh and it's the Duratec engine.
hope at least someone will have a clue as I'm stumped frankly.
Many thanks :)
