tark99
Member Since 22 Nov 2012
Offline Last Active Apr 23 2015 05:18 PM
In Topic: Side Skirts
06 March 2013 - 05:37 PM
hi
thanks lads the £200 was for painting and fitting. wot i'm worried about buying off sites like e-bay is they say it's genuine ford skirts,and then they say moulded from original ford skirts and i'm worried they are not going to fit right.
In Topic: Anything To Look Out For?
30 January 2013 - 03:39 PM
Hi rossrr
When you check the carpets for water leaks make sure you realy press down hard because mine came in between the trim and bodywork and up through the underlay
In Topic: Driver Side Front And Back Water Leak?!
30 January 2013 - 03:30 PM
Hi NickiMac
ford did charge me first time and when i read other members reviews one found out it was a production fault so i gave ford relations a call and explain to them what had happned, i took the car back and they didn't charge me, my car was first registered 2010
and only done 14,000 mls so i don't know if that ad anything to do with it.
17 January 2013 - 05:23 PM
hi tommy
I hope i can get the pics through to yer, me and pc don't get on, it does look bad on the photo's it looks if they was blindfolded
when they did it.
anthony B)
14 January 2013 - 01:03 PM
hi tommy
sorry i can't help you with what seal it was but mine ad gone in two places, one at the top of the wing
just below the bonnet hinge you can see the seal where they have put some touch up paint on it, the other one was where the wing fits on to the bodywork the guy was pointing to the door pillar between
drivers door hinges, the water was running in between the trim and sill and coming in at the back of drivers seat up through the underlay and carpet in the passenger footwell,so far so good, they did say bring it back if it happens again, i'm sorry if it's not much use and hope you get it sorted soon there must be thousands out there with this problem fords should know it must be a major problem.
