JamieWaldie1992
Member Since 25 Nov 2012
Offline Last Active Mar 21 2013 07:24 PM
In Topic: Two Fusion 3 Questions
05 March 2013 - 01:52 PM
they run a lot less power and last a lot longer but not sure if they're 100% legal but seems stupid if they're not :/ i think they're just a straight swap with your normal bulbs as long as the bulb type's the same and I agree with Stoney841, check online for a default code or see if the manufacturer can help you directly :)
05 March 2013 - 01:37 PM
Ahh right  :unsure: no idea then sounds like the bluetooth thing is affecting it. Have you checked the rear lights yet?
No problem :)
05 March 2013 - 12:16 AM
Not sure about any aftermarket Bluetooth stuff but when you say the console lights up do you mean when you lock it? The screen in the dashboard and the radio screen should stay lit up for roughly 15 minutes after locking it, assuming you have the same spec and radio as me (Zetec and 6000-CD) as for the rear lights there's a wingnut on the back of the cluster (under a flap) according to the owner's manual that you have to undo to remove it, after that it should be the same as a Fiesta (my Dad had one a while ago). I hope that helps :D
01 March 2013 - 03:37 PM
yeah i was the same when i got mine and the major one was "does no-one make any cool stuff for a fusion?!" :/
01 March 2013 - 03:33 PM
might be with mine being a newer model but other than that i have no ideas :/
