Member Since 25 Nov 2012
Offline Last Active Dec 09 2012 04:51 PM
Mk2 2.0 Duratec Gear Lever Return Spring
25 November 2012 - 06:31 PM
I've recently picked up a mk2 '54 plate focus with 2.0 petrol engine.
The gear lever spring appears to be broken as the lever won't naturally return from the 1st/2nd position to the 3rd/4th position in the middle, as in shifting from 2nd to third.
I've read on here that this is a common problem on the 1.6 mk1s and that the spring can be changed easily for this part. http://www.fordparts...42069_c_100.htm
Does the mk2 2.0 have a different box and if so is it still possible to replace the spring?
Any help much appreciated as I'm new to fords.
