jpunter22
Member Since 27 Nov 2012
Offline Last Active Dec 06 2012 07:51 AM
In Topic: smax official trouble topic
30 November 2012 - 08:11 AM
Hi everyone
I have got a 2007 2.0 tdci smax and i have a few problems which I'm trying to get to the bottom of.
1. There is a constant whinning/buzzing noise inside the car. I have been told by a garage that its the electric power steering motor/pump and this is normal on these, can anyone clarify that this is the case as I'm not sure this is true.
2. When i'm driving the car I get a lurching motion at low settled revs (doing 30mph in 4th gear, in second when you are turning into junctions). There is plenty of power there when i accelerate a bit but when I let it settle again it starts doing it again. I have been told by the same garage its because its a heavy car and that I just need to be in a lower gear, which does sort the problem but I have never had in all my years driving a car that you have needed to change into first gear to turn into junctions or not been able to be in 4th gear doing 30mph. I have heard stories about the dual mass flywheels being an issue on these and was woundering if anyone can help.
3. Last one now. When i put the car into reverse the parking distances system does a continuous beep for about 10 seconds then only seems to work sometimes or eraticly. I have noticed that the rear sensors have no longer got the black coating on them and that there is a some white powder on a couple. Could this be the cause of the problem as the front ones are fine and seem to work still.
I would really appriciate some help on these issues if anyone has experenced or had similar problems, and how they were solved or if they can be sloved. Many thanks for any help in advance.
Jamie
